ENC Gateway Policy Group
The ENC Gateway policy group lets you view or edit the existing computer policy properties for the extended network connectivity (ENC) communication components and services. The ENC Gateway provides a virtual network environment where you can create links among enterprise managers, domain managers, scalability servers, and agents that are all operating behind different firewalls.
You can modify most policy parameter values by double-clicking a policy to display the Setting Properties dialog or the Modify Settings dialog, where applicable. However, to view or edit the policy parameter values in the ENC Authorization Rules policy group, you must use the ENC Authorization Rules configuration view.
Note: For more information on how to configure the ENC Gateway, see the Implementation Guide.
The ENC Gateway policy group contains the following subfolders:
