Asset Management Policy Group (Manager)
The Asset Management policy group lets you view or edit the following NIST SCAP support policies. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Specifies the location of the storage folder for SCAP scanner result files. The default is to create a SCAP_Result_Files directory under the CA ITCM install location.
