Asset Collector Policy Group (Manager)
The Asset Collector policy group lets you view or edit the existing configuration policy parameters for the Asset Collector at the manager level. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
This policy group contains the following policies:
Specifies the frequency interval in days before the Asset Collector audit record table is purged.
Default: 30
Species the number of days after which the Asset Collector audit records will be deleted automatically.
Default: 180
