Previous Topic: ENC Gateway Server Policy GroupNext Topic: Encryption Policy Group
Secure Socket Adaptor Policy Group
The Secure Socket Adaptor policy group contains the following policies for the Secure Socket Adaptor (SSA). You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Emulate DSM Pmux protocol
If set to True in the global configuration, the connection broker listens on the DSM port multiplexer’s port (and UNIX domain socket on UNIX/Linux platforms).
Typically, this parameter is only changed for troubleshooting purposes. If this value is changed, the SSA port multiplexer will be restarted.
Default: True, <locally managed>
Exclude SSA provider list
Lists the SSA providers to be excluded if the connection address uses ENC. (This is a semicolon separated list.)
Default: empty, <locally managed>
Include SSA provider list
Lists the SSA providers to be included if the connection address uses ENC. (This is also a semicolon separated list.) The provider that might usefully be included is SSL. For example, where ENC provides its own security, SSL might be excluded. Alternatively, if ENC does not provide any security of its own, the SSL might be included, but not used on communications within the local network.
