Backwards Compatibility Policy Group
The Backwards Compatibility policy group lets you view or edit the following Agent Bridge support policy for agent UUID generation for mobile PDA and legacy agents. You can modify policy parameter values by double-clicking the policy to display the Setting Properties dialog.
Controls the agent UUID generation behavior of the Agent Bridge. If enabled (True), the Agent Bridge generates and maintains a host UUID for any mobile agent or legacy agent that does not report one. The generated host UUID is derived from the host name of the computer. If False, agent UUID generation is disabled.
Note: If the computer’s host name is changed, a new host UUID will be generated and a new computer will be registered.
Default: False
