Previous Topic: Common Configuration Policy Group (Scalability Server)Next Topic: Backwards Compatibility Policy Group
Common Server Policy Group
The Common Server policy group contains the following policies. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Engine name
Specifies the name of the engine.
Default: empty, <locally managed>
Exclude SD library
Specifies whether a software signature scan should exclude the Software Delivery Library path. If True, the contents of all Software Delivery Library packages are excluded, that is, ignored, during a software scan. If False, any packages or executables found in the Software Delivery Library are included in the software scan and treated as if they were staged.
Default: True
Manager Host
Specifies the host name of the manager.
Default: localhost, <locally managed>
Registration timeout
Specifies the time interval in seconds between registration attempts, for example, 300 seconds.
Default: 300, <locally managed>
Worker threads
Specifies the number of worker threads.
Default: 1, <locally managed>
The Common Server policy group also contains the following policy group folder:
