Port Multiplexer Policy Group
The Port Multiplexer policy group lets you view or edit the existing computer policy properties for proxy multiplexers. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Specifies the port to which the port multiplexer connects and listens in on remote computers.
If this value is changed, the SSA port multiplexer will be restarted.
Default: 4728
