TCP Policy Group
The TCP policy group contains the following Internet Protocol (IP/TCP) specific policies. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Note: Windows 95/98/Me allow up to 100 concurrent TCP connections. When this default limit is reached, a WinSock error is reported (10055 - WSAENOBUFS). If this limit is exceeded, the CA product may act unpredictably. For further information, see the Microsoft Knowledge Base at http://support.microsoft.com.
Specifies the timeout interval in seconds for connections.
Default: 10
Specifies the timeout interval in seconds for ENC connections.
Default: 90
Indicates whether the TCP protocol is enabled.
Default: True
Indicates whether the Nagle algorithm is enabled.
Default: True
Specifies the default TCP port. This is a virtual port that is connected by the port multiplexer to a real physical port.
Default: 3000
Specifies the timeout interval in seconds for send operations.
Default: 60
