Previous Topic: Audit Policy GroupNext Topic: Data Transport Agent Plugin Policy Group
Data Browser Agent Plugin Policy Group
The Data Browser Agent Plugin policy group contains the following policies for configuring the DTS Browser, including DTS shares. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Note: The DTS Browser used to be called the Data Objects Agent (DOBA).
DTS Browser protocol parameters
Specifies the ports to listen for incoming transfer requests.
Default: RPORT=<8300> SPX_RPORT=<8301>
DtsShares table
Defines the DTS Shares table, which allows aliases to be associated with directories.
Default: empty
Enable DTS Shares
Enables DTS shares that are configured using the DTS Shares table, if True. You can add, delete, and edit shares in this table.
Default: False
Ignore CDROM drives
Specifies that CD-ROM drives not be browsed, if True.
Default: True
Ignore mapped drives
Specifies that mapped drives not be browsed, if True.
Default: False
Ignore removable drives
Specifies that removable drives not be browsed, if True.
Default: True
Security mode
Determines whether incoming transfer requests must be authenticated. Responses to security violations are dependent on the current security mode. Valid values are as follows:
quiet
Disables security checking.
warn
Enables security checking. If an invalid request is detected, the operation is permitted to continue. However, the violation is recorded in the log file to indicate the occurrence.
fail
Enables security checking. If an invalid request is detected, the operation is immediately aborted. When fail mode is enabled, users are required to enter a valid user name and password before they are able to display or set the runtime parameters for any of the DTS computers.
Default: fail
