Previous Topic: Data Transport Service (DTS) Policy GroupNext Topic: Data Browser Agent Plugin Policy Group
Audit Policy Group
The Audit policy group contains the following DTS auditing policies. If the audit messages are empty, then the default audit message is enforced by the agent. The default message is dependent upon the locale where the agent has been installed; so, for example, if the German version of the agent has been installed, then the default audit message will be in German. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog. As with all policies, the values set here override the default values used by the agent, regardless of locale.
Agent started message
Indicates the message issued when auditing is started.
Default: ${DT} ${TT} DTS auditing started.
Agent stopped message
Indicates the message issued when auditing is terminated.
Default: ${DT} ${TT} DTS auditing stopped.
Agent: transfer abort message
Indicates the message issued when a transfer that specifies this agent as the initiator or responder aborts.
Default: ${DT} ${TT} Transfer ${XD} from ${XF} to ${XT} aborted.
Agent: transfer complete message
Indicates the message issued when a transfer that specifies this agent as the initiator or responder completes successfully.
Default: ${DT} ${TT} Transfer ${XD} from ${XF}::${XS} to ${XT}::{XK} completed.
Agent: transfer fail message
Indicates the message issued when a transfer that specifies this agent as the initiator or responder fails.
Default: ${DT} ${TT} Transfer ${XD} from ${XF} to ${XT} failed; error message=${XX}.
Agent: transfer resume message
Indicates the message issued when a transfer that specifies this agent as the initiator or responder resumes after having been suspended.
Default: ${DT} ${TT} Transfer ${XD}from ${XF}::${XS} to ${XT}::{XK} resumed.
Agent: transfer start message
Indicates the message issued when a transfer that specifies this agent as the initiator or responder starts.
Default: ${DT} ${TT} Transfer ${XD} from ${XF} to ${XT} started.
Agent: transfer suspended message
Indicates the message issued when a transfer that specifies this agent as the initiator or responder is suspended.
Default: ${DT} ${TT} Transfer ${XD} from ${XF} to ${XT} suspended.
NOS failed message
Indicates the message issued when the Network Object Server fails during normal operation, not during startup. If the Network Object Server fails during startup, the default message, not the audit message, is displayed.
Default: empty
NOS started message
Indicates the message issued when the Network Object Server starts.
Default: empty
NOS stopped message
Indicates the message issued when the Network Object Server stops.
Default: empty
SOS failed message
Indicates the message issued when the Schedule Object Server fails during normal operation, not during startup. If the Schedule Object Server fails during startup, the default message, not the audit message, is displayed.
Default: empty
SOS started message
Indicates the message issued when the Schedule Object Server starts.
Default: empty
SOS stopped message
Indicates the message issued when the Schedule Object Server stops.
Default: empty
TOS failed message
Indicates the message issued when the Transfer Object Server fails during normal operation, not during startup. If the Transfer Object Server fails during startup, the default message, not the audit message, is displayed.
Default: empty
TOS started message
Indicates the message issued when the Transfer Object Server starts.
Default: empty
TOS stopped message
Indicates the message issued when the Transfer Object Server stops.
Default: empty
TOS: transfer aborted message
Indicates the message issued when a transfer aborts.
Default: empty
TOS: transfer completed message
Indicates the message issued when a transfer completes successfully.
Default: empty
TOS: transfer failed message
Indicates the message issued when a transfer fails.
Default: empty
TOS: transfer job aborted message
Indicates the message issued when a transfer job aborts.
Default: empty
TOS: transfer job completed message
Indicates the message issued when a transfer job completes successfully.
Default: empty
TOS: transfer job failed message
Indicates the message issued when a transfer job fails.
Default: empty
TOS: transfer job resumed message
Indicates the message issued when a transfer job resumes after having been suspended.
Default: empty
TOS: transfer job started message
Indicates the message issued when a transfer job starts.
Default: empty
TOS: transfer job suspended message
Indicates the message issued when a transfer job is suspended.
Default: empty
TOS: transfer resumed message
Indicates the message issued when a transfer resumes after having been suspended.
Default: empty
TOS: transfer started message
Indicates the message issued when a transfer starts.
Default: empty
TOS: transfer suspended message
Indicates the message issued when a transfer is suspended.
Default: empty
Back to Top
