Specify User Credentials
Use the User Credentials dialog to specify user credentials for the discovered computer that you have selected as a target computer for the deployment payload. Specified user credentials are required before deployment is possible.
To specify user credentials
Note: This field can be left blank if the target computer has a blank password (not advised).
Note: The credentials are not tested at this point; invalid credentials will only be detected when the deployment is active.
