Previous Topic: Deployment JobsNext Topic: Specify a Deployment Job and Type
How to Deploy Components
The Infrastructure Deployment Wizard lets you deploy CA ITCM components to your environment using a deployment job that sweeps your network. It is a task-oriented wizard that guides you through the process of creating a job and specifying the settings for deploying one or more agents or a scalability server to target computers.
The basic steps for creating a deployment job are as follows:
  1. Specify the deployment job name and type.
  2. Select a DSM software package to deploy.
  3. Specify deployment target criteria.
  4. Scan the target computers to make sure that the software packages can be deployed on the targets.
  5. Select the scanned computers on which to install the software package.
  6. Specify additional agent configuration and installation details for the deployment payload when it is delivered.
  7. Review the specified settings and deploy the software package.
