The DSM Explorer › Control Panel › Deployment › Deployment Jobs › How to Deploy Components › Select Targets for Deployment
The Target Selection wizard page lists the computers found by the scan, letting you select the computers by name and address on which to install the agents.
To add a computer to the list of target computers
- Select the computer in the Discovered Computers list and click the right-arrow icon.
The computer is added to the Target Computers list.
- (Optional) To select all the computers in the list and move them to the Target Computers list, click the double arrows icon.
- Specify user credentials for the target computer, if required. This is indicated by the appearance of the User Credentials dialog when a computer with that criterion is added to the target list.
- Click Next to go to the Agent Configuration page.
