Previous Topic: Computer Properties: OS Installation Management TabNext Topic: Asset Context Menu Options
Software Delivery Tab
The Software Delivery tab displays fields that control the software delivery specific aspects of a computer or a user profile:
Status:
Operational / Locked by RAC / Locked by Move / Locked by Roam / Locked by Migration / Locked by RAC & Move / Locked by RAC & Roam
Download method:
Internal - NOS
Internal - NOS-less
DTS NOS-less
Job Calendar:
Name of the job calendar used.
RAC Policy:
Common
The common policy will be used for this computer.
Automatic
A RAC job container will be created and activated, starting the delivery of job orders to the computer.
Deferred
A RAC job container will be created. It can be reviewed and modified, since it has to be activated manually.
Disabled
RAC is disabled on this computer. No job container is set up for this computer. However, its installation records in the installations folder on the manager will be marked as removed.
For more information see, Modify the Reinstall After Crash (RAC) Policy (Wipe and Reload Migration Only)
Software Managed system:
This box should be checked if the computer is a software managed system (that means, it is only using software installed by CA ITCM, and this software was registered into the software package library using CA's Software Management Packager.).
If you try to install software not created and registered by that Packager on such a computer, the job will fail with an error code stating that the "Procedure is not allowed to run on the target system because it is marked as Software Managed".
