The OS Installation Management tab displays information about OS Installation Management.
This tab contains the following fields:
Enables this computer for OS Installation Management If the check box is selected. If the check box is not selected, you can select it.
Identifies the name of the computer.
Identifies the DNS name of the host.
Identifies the MAC address of the computer. If the MAC address is not shown, you have to enter it here.
Displays the name of the operating system image. If <None> is displayed, you can assign an image later.
Specifies the name of the boot server.
Important! If the computer is not yet managed by OS Installation Management, you must specify the Name, the Host Name, and the MACAddress of the computer.
