Previous Topic: SXP Package PathNext Topic: Register / Import Software Package as New Version
WIN CE Package Path
Files
Use the Browse button to select the proper path to the WinCE cabinet files, or the WinCE Application Manager files.
Source is on manager
Check this box, if you are using the CA ITCM Explorer on another computer than the domain manager itself and you want to give the path to a local drive on the domain manager (as seen by the manager). Otherwise, do not check the box. If this box is checked, the Browse button is grayed out.
Note: If you use this option, you cannot use UNC paths: You have to manually map a drive at the manager to the actual location and use that path instead. For example, if the UNC path is \\Server\share\dir, map x: to \\Server\share and then use the path x:\dir instead of the UNC path.
Seal package
By checking the Seal package box, the package will be automatically sealed when registered.
This registration method should be selected, if upon registration you intend to send install orders, using the local install procedures, to the appropriate agents. These procedures are the only ones that can be used (to perform a local installation), until the Administrative installation procedure has been utilized.
