To register / import a software package as new version you have to enter information about the software package source:
Enter the path to a directory where the software package registration information resides (reginfo directory) or use the Browse button to walk through the Explorer folder tree to the directory.
Alternatively you can select the Source is on manager check-box
If you create a New Version of an existing software package, this version will be created as "Generic (Open)". To seal an open package, see Seal.
