Please enter the path to the PKG, PIF or RPM package.
Use the Browse button, to select the proper directory of the PKG, PIF or RPM package file(s).
In all three cases, you are allowed to change the pattern and you can expect a data stream file.
Optionally, only for PIF and PKG, response files are possible, of any pattern.
Use the browse button to select the proper path for the response files.
The response files will be used as input files for unattended installation of PKG or PIF packaged products.
An individual install procedure is automatically created for each response file.
