Previous Topic: Session Information DialogNext Topic: Rejected Sessions Pane
Previous Sessions Pane
Select the Remote Control, Previous Sessions node to populate the Previous Sessions pane with a list of sessions that were initiated earlier to hosts controlled by the current Remote Control domain manager. You can switch between sessions by selecting one from the Previous Sessions pane. You can view details by double-clicking a particular session to access the Session Information dialog.
This pane contains the following fields:
Information
Displays pane-specific tips for selecting options or entering information.
Start Time
Displays the time that the remote control session started.
Host
Displays the computer name of the remote control host.
Viewer
Displays the computer name of the remote control viewer.
Remote User
Displays the user name or ID of the session's remote user.
Duration
Displays the length of the remote control session.
