The Active Replays context menu provides the following options for working with active replays:
Begins playing back a recorded session frame by frame. Valid options are as follows:
Slows the active replay to half the speed of the original session.
Replays the session at the actual speed recorded during the original session.
Fast forwards the active replay at double the speed of the original session.
Default: Normal Speed
Pauses the recorded session being played back.
Provides scrolling options that let you control the host image. Valid options are as follows:
Displays the host image in the viewer window without modification.
Shifts to display the active area as the mouse moves around the screen. This option applies to a viewer computer with a smaller resolution than the host computer.
Scales or shrinks the host image to fit the viewer window.
Shrinks the host image to fit the viewer window.
Scales the host image proportionally in the viewer window. This option applies to Scale to Fit and Shrink to Fit modes.
Rewinds the active replay.
Closes the recorded session being played back.
