Previous Topic: Delete a Recorded SessionNext Topic: View Recently Replayed Sessions
Clear the Recently Recorded Sessions Folder
You can clear the contents of the Recently Recorded Sessions folder at any time.
To clear the contents
  1. Right-click the Recently Recorded Sessions node.
  2. Click Clear Shortcut List in the context menu that appears.
    All recently recorded sessions are removed from the shortcut list, but the actual recording files are not deleted.
Note: If you want to remove individual sessions, right-click each session that you want to clear and click Remove Shortcut. Likewise, the session is removed from the shortcut list, but the actual recording file is not deleted.
