Previous Topic: Open a Recorded SessionNext Topic: Delete a Recorded Session
Play a Recorded Session
You can replay any recorded session.
To play a recorded session
  1. Open the recorded session.
    The session is added to the Active Replays node, and playback starts automatically.
  2. (Optional) Right-click the recorded session if you want to change the playback speed, and click Play.
    A submenu opens, letting you select a replay speed.
  3. Select the speed at which you want to view the recorded session. Valid options are as follows: Slow Motion, Normal Speed, and Fast Forward. The default is Normal Speed.
    The recorded session plays back the session (frame by frame) at the speed you selected.
Note: You can change the active replay session speed at any time after the file has been opened, even while playback is in progress.
