Previous Topic: Define Directory Search DialogNext Topic: Add Argument Dialog - Software Packages
Add Argument Dialog
The Add Argument dialog displays the inventory and template information that you can query.
Operator
Specifies an operator for the argument. In addition to the relational operators, you can select the following operators. These operators compare the previous value of the selected inventory and its current value.
Increased
Returns true if the value has increased from the previous scan by the specified number.
Decreased
Returns true if the value has decreased from the previous scan by the specified number.
Changed
Returns true if the value has changed from the previous scan.
Doubles
Returns true if the value has doubled since the previous scan.
More information
Query Designer Dialog
Operators
