Previous Topic: Add Argument DialogNext Topic: Add Argument Dialog - Discovered Software
Add Argument Dialog - Software Packages
The Add Argument—Software Packages dialog lets you query deployed and staged software on all of the agent computers.
This dialog has the following fields:
(Query Criteria)
Displays the software package query criteria for either deployed or staged packages.
Click Deployment to view and specify the following query criteria for deployment software packages: SW Name, SW Procedure, and SW Version.
Click Staging to view and specify the following query criteria for staged software packages: SW Name and SW Package.
Package Name
Specifies the name of the software package to be queried, for example, CA ITCM Manager.
Package Version
Specifies the version number of the software package, for example, 12.0.0.3888 for CA ITCM Manager.
Status (Deployment)
Specifies the status of the deployment software package. Valid statuses for deployment packages are as follows:
Deployed
Returns targets where the specified software package is successfully deployed.
Deploying or Deployed
Returns targets where the specified software package is being deployed or successfully deployed.
Deploying
Returns targets where the specified software package is being deployed.
Deployment failed
Returns targets where the specified software package is not successfully deployed and has failed deploying.
Default: Deployed
Status (Staging)
Specifies the status of the staged software package. Valid statuses for staged software packages are as follows:
Staged
Returns targets where the specified software package is successfully staged.
Staging or Staged
Returns targets where the specified software package is being staged or successfully staged.
Staging
Returns targets where the specified software package is being staged.
Staging failed
Returns targets where the specified software package is not successfully staged and has failed staging.
Default: Staged
Procedure
Deployment only: Specifies the software procedure to be used for querying. Use the drop-down list to select the relevant procedure.
Ordered By
Specifies the user ID of the person who ordered the software package.
Creation Time
Specifies the creation timestamp of the relevant deployment or staging job.
Package Created
Specifies the creation timestamp of the software package.
Package Supplier
Specifies the supplier of the software package.
Package Comment
Specifies any comment or descriptive text associated with the software package.
