Previous Topic: Add Argument Dialog - Software UsageNext Topic: Add Policy Argument Dialog
Add Argument Dialog - File Contents
The Add Argument—File Contents dialog for file contents lets you select the configuration file or file group you want to query.
This dialog has the following fields:
Configuration Files
Displays the configuration file groups and files in the domain. Click the file group to view the configuration files under it. You can search all the files under a group or search a particular file for the given value.
Operator
Displays the Like operator that you can use for performing wildcard search.
Value
Defines the text you want to search in the configuration file or file group. As the entire configuration file is searched for the given value, the value needs to have a wildcard character. Specifying a value without a wildcard character returns true only if the entire file contents match the given value.
For example, if you are searching for the word Timeout in the config.sys file, you need to give the value as Timeout*.
More information:
Query Designer Dialog
