Previous Topic: Add Argument Dialog - File ContentsNext Topic: Add Directory Argument Dialog
Add Policy Argument Dialog
The Add Policy Argument dialog lets you select a query based policy or an event-based policy that you want to query.
This dialog has the following fields:
Select Policy
Displays either the query-based or the event-based policies in the domain, depending on the policy type selected in the Query Designer dialog. Select a query-based policy to view the assets that have violated the policy, or select an event-based policy to view the assets that have triggered the policy.
Violation or Event should have occurred within the past...Days
Displays the violation or event that occurred within the specified number of days. If you want to view all the violations or event triggers, clear this option.
