The Add Argument—Software Usage dialog for software usage lets you query the software usage information.
Note: Available categories and options may vary depending on the products and components installed.
This dialog has the following fields:
Displays the software definitions in the domain. Click Categories to view the definitions grouped by Categories. Click Manufacturers to view the definitions grouped by manufacturers.
For any of the following fields, you can select ignore if you do not want to query the field:
Specifies the action to be queried.
Defines the start date and time for observing the usage information.
Defines the stop date and time for observing the usage information.
