Previous Topic: Policy Designer Dialog: Service DeskNext Topic: Policy Designer Dialog: Add Action
Policy Designer Dialog: Evaluation
The Evaluation section lets you specify how you want the policy to be evaluated.
This section contains the following fields:
Always evaluate Policy when a collect task is performed
Specifies whether the policy should be evaluated each time a collect task is performed. Hence, selecting this option is useful whenever you want to get a current snapshot.
Note: This option is system resource-intensive. Select this option only for critical policies.
Designate Engine to evaluate Policy
Specifies whether the policy should be evaluated by the engine.
Engine
Specifies the engine that evaluates the policy.
Update interval
Defines the interval between each evaluation of the policy. The selected engine evaluates the policy at the specified interval.
