Previous Topic: Policy Designer Dialog: EvaluationNext Topic: Add Action: Notification
Policy Designer Dialog: Add Action
Use the Add Action section to insert an action, view the action properties, or remove an action. Clicking each of the Add Action items opens a separate dialog where you can set action-specific configurations.
The available policy actions are as follows:
Notification
Displays a message on the Windows agent computers where the selected users are logged in.
Message
Displays a message on the violated Windows agent computer. Unlike Notification, messages are not specific to users.
Schedule Job
Schedules a job to be executed on the violated assets.
Launch Application
Executes an application on the violated assets.
Add to Group
Adds the violated asset to a group.
Generate Text File
Appends text to a text file.
Send Mail
Sends email to the specified recipients
Delete Asset
Removes violated asset from the DSM domain.
Note: If one or more software delivery jobs are linked to an asset, the asset will not be removed until these jobs are unlinked. See Unlink a Job from an Asset for more information.
System Event Log
Logs the given information in the system event log.
SNMP Trap
Triggers an SNMP Trap
Context Menu Options
The following options appear when you right-click an action type in the right pane:
Remove
Removes the inserted action from the policy.
Properties
Displays the properties of the inserted action in a separate dialog.
