Previous Topic: Edit an Existing JobNext Topic: Run the Asset Job Check
View the Job Status
You can view the detailed status information of the selected job or task.
To view the job status
  1. Navigate to the appropriate Asset Jobs folder.
    The existing asset jobs are displayed.
  2. Right-click the job and select Status.
    The Action Status dialog appears.
  3. Review the status information in the following fields:
    Job
    Displays the name of the selected job or task.
    Asset
    Displays the name of the computer to which the job is linked.
    Status
    Displays the status of the job or task. An enabled job or task can have the following status:
    OK
    Indicates that the job or task has executed without any errors.
    Waiting
    Indicates that the job or task has never been executed. After the first run, the status is changed to OK or Error.
    Error
    Indicates that the job or task is executed with errors.
    Note: If a job or task is disabled, its status is shown as Disabled
    Date
    Displays the date when the job or task was last executed.
    Runs
    Displays the total number of times a script or command job was actually run. This total includes both jobs that have run successfully and those that resulted in an error status.
    Successful Runs
    Displays the number of times a task was successfully run.
    Canceled
    Displays the number of times the job or task was canceled.
    Elapsed Time
    Displays the time elapsed during the last job or task execution.
    Status Comment
    Displays the status comment for the job or task.
  4. Click Close.
