An asset job directs agents to perform specific actions on a computer or when a user logs in. You can, for example, use asset jobs to run a script or command, and display a message.
Jobs can be created at the asset, group, and domain level. Jobs created at the asset level are linked to the respective assets, and those at the group level are linked to all the member assets in the group. At the domain level, you can view all the jobs in the domain, create new jobs, and link it any group or asset. You can create and link any number of jobs to a particular asset or group.
The Asset Jobs folder displays all the asset jobs created in the domain. You can use this folder to create, manage, and schedule asset jobs. These jobs can be linked to any asset or group in the domain. Asset management provides various predefined command jobs that perform basic and crucial tasks such as virus scanning, checking the disk, and so on. You can run and schedule these jobs on any computer.
Note: You can drag a job to an asset or group on which you want to execute the job.
