Previous Topic: Origin and Trust Level of an AssetNext Topic: Create a New Asset Job
Asset Jobs Pane
The Asset Jobs pane displays all the asset jobs linked to the current asset or group. In this pane, you can create, link, disable, unlink, schedule, and reorder the asset jobs.
This pane contains the following columns:
Job
Displays the name of the asset jobs.
Order
Displays the order in which the jobs are executed. By default, the jobs are sequenced in the same order in which you link them. However, you can also reorder them to meet your requirements.
Status
Displays the Status of the jobs.
Last Executed
Displays the date and time when the jobs were last executed.
Status Text
Displays the status comment if any.
Linked At
Displays the name of the computer where the job was linked.
Disabled At
Displays the name of the computer where the job was disabled. If you have disabled the job in the selected computer, this field shows the selected computer name.
Context Menu Options
The Context Menu for a job contains the following menu items:
Note: Some of these menu items are also available in the Tasks section.
Reorder
Opens a submenu where you can reorder your jobs. You can move a job up and down and as first or last. You can also set a position for a specific job. The jobs are executed in the same order as they appear in this pane. Reordering the jobs is important if the execution of one job depends on the execution of another.
New
Opens the Create New Job wizard that lets you create a new job for the asset or group.
Disable/Enable
Disables or enables the job on the selected asset or group. Select this option when you want to temporarily enable or disable the job on the asset or group.
Unlink
Unlinks the job from the selected asset or group. You can select this option when you no longer want to perform the job on the asset or group.
Status
Opens the Action Status dialog showing detailed information about the status of the job.
Scheduling
Opens the Scheduling Options dialog where you can configure the scheduling for the selected job.
Properties
Opens the Job Properties dialog for the selected job.
