Previous Topic: Run the Asset Job CheckNext Topic: Unlink a Job from an Asset
Link a Job to an Asset
You can find the jobs that are not linked to the selected asset or group of assets, and then select the appropriate jobs to be linked to the asset.
Note: This feature is not available for some CA component plug-ins and applications.
To link a job to an asset
  1. Navigate to the appropriate Asset Jobs folder.
    The Asset Jobs pane appears.
  2. Click Link Existing Asset Job in the Tasks section.
    The Select Asset Jobs dialog appears.
  3. Select the asset jobs you want to link, and click OK.
    Selected jobs are added to the Asset Jobs pane.
Note: To select multiple items all at once, press the Shift key (continuous selection) or Ctrl key (random selection) and click the items.
