Previous Topic: Remote Control NodeNext Topic: My Sessions Pane
My Computer Pane
The My Computer pane displays the My Documents folder and all of the local and network drives on your computer.
You can create a new folder under a drive by right-clicking on the drive and choosing Create Folder from the context menu. You can also select a file or folder and copy, rename, or delete it by clicking the corresponding command from the context menu. If you copy a file, you can paste it to a different drive or folder by clicking Paste.
More Information:
File Transfer Feature
