Previous Topic: Remote Control ViewerNext Topic: My Computer Pane
My Computer Node
The My Computer node contains the My Documents folder and all the local and network drives that are available on your computer. Expand the My Computer folder to view the files and folders on the local computer in the My Computer pane.
When a remote control session is active, the remote computer's drives appear below the tree node for each session. You can transfer files locally or to and from remote hosts using drag-and-drop functionality or Cut and Paste context menu commands.
