A computer with two or more monitors can also be used by Remote Control. The image on all monitors is transmitted to the viewer, which provides a window that can be scrolled sideways to see all monitors. The remote system appears as an extra wide, single monitor.
Linux: To use multiple monitors, your computer must be running with PanoramiX/Xinerama enabled
The Remote Control viewer component can be used on any multiple monitor system.
Note: Full Screen Mode in the viewer is displayed on the primary monitor only.
