There are multiple methods for accessing the Replay Export tool.
To access the Replay Export tool, choose one of these methods
Quick Export automatically starts the conversion process using default encoding options and requires no further input.
Export to Video invokes the Export Options dialog, letting you view or modify the default encoding options before starting the conversion process.
For example, the following command converts all of the recording files in the current folder to Windows Media Video format, using the best available codec and default encoding options:
rcReplayExport /WMV *.urc
