Configure Scalability Server for Locations Rule
The Scalability Server column values You can specifydefine the IP address FQDN (Fully Qualified Domain Name) of a scalability server for the agent to connect to, using the Scalability Server column.
The Setting Properties dialog opens.
The scalability server to the location rule is configured.
Note: If you specify the Scalability Server, leave the Subnet Scan and Script columns empty. If you are not using the Scalability Server, leave the Scalability Server column empty.
