The DSM Explorer › Control Panel › Configuration Folder › Configuration Policy › Default Computer Policy (or User-Defined Policy) Node › Agent Policy Group › Common Agent Policy Group › Common Policy Group (Common Agent) › How to Enable and Configure Location Awareness
Apply the Location Awareness to Agents
After you create and seal a policy, apply it to an asset (a computer or group).
Follow these steps: (To an Asset)
- Navigate to the Configuration Policy folder under the Control Panel node in the tree view.
- Right-click the policy to apply, and select Copy from the context menu.
- In the tree view, navigate to the asset, right-click it, and select Paste from the context menu.
The policy is applied to the asset.
Follow these steps: (To Multiple Assets or Groups)
- Select the assets or groups in the tree view.
- Right-click the highlighted targets and select Paste from the context menu.
Another context menu appears.
- Click Configuration Policies.
The Schedule Policies dialog opens.
- Schedule the policy to be activated.
Note: When you apply policies to a single asset or group, the feature enables the Customize and Preview button. The feature disables the button if you paste a policy to multiple assets or groups.
- Click OK to apply the policy to the multiple assets or groups.
You have successfully enabled and configured the location awareness feature for the DSM agents.
