Previous Topic: Collect Tasks - Group LevelNext Topic: Create a New Collect Task
Collect Tasks - Asset Level
The Collect Tasks pane at the asset level displays all the collect tasks linked to the asset and their current status. In this pane, you can create, link and unlink the collect tasks from the asset.
Note: The collect tasks available at the group level are automatically linked to the member assets. At the asset level, you can only disable these tasks.
This pane contains the following columns:
Name
Displays the name of the collect tasks linked to the asset.
Type
Displays the collect task type.
Status
Displays the status of the collect task.
Last Executed
Displays the date and time when the task was last executed.
Status Text
Displays the status text if any.
Linked At
Displays the computer or group from which the task was linked.
Disabled At
Displays the computer or group from which the task was disabled.
Context Menu Options
The Context menu contains the following options, available when you right-click a collect task at the group or asset level:
New
Displays the Select new Collect Task Type dialog that lets you create a new collect task.
Enable/Disable
Enables or disables the selected collect task. Select this option when you want to temporarily enable or disable the task on the asset.
Unlink
Unlinks the selected collect task from the asset. Select this option when you no longer want to perform the collect task on the asset.
Status
Displays the Module Status dialog.
Scheduling
Opens the Scheduling Options dialog enabling you to configure the scheduling for the selected collect task.
Properties
Opens the Properties for collect task dialog depending on the selected collect task type.
More information:
Scheduling Options Dialog: Scheduling Tab
View the Job Status
