Collect tasks gather hardware, software, template, and virtual host inventories. You can also configure a collect task to collect file scan and software usage information. Use the Select new Collect Task type dialog to select the type of collect task.
To create a new collect task
The Select new Collect Task type dialog appears.
Note: Software usage collect tasks can only be created for a specific group or asset. Navigate to the group or asset to create a software usage collect task.
Note: Virtual host inventory collect tasks can only be created in the context of an asset having the AM remote agent installed. Navigate to the appropriate asset to create a virtual host inventory collect task.
The Schedule New Collect Task dialog appears. Depending on the type selected, the appearance of subsequent dialogs, tabs, and actions may vary.
The Scheduling Options dialog appears.
A new collect task is created with the given name.
