Previous Topic: Search Files Based on the Modified DateNext Topic: Unknown
Search Files Based on the File Size
If you want to search for a file based on the file size, you can specify the search criteria in the Advanced tab.
To search files based on the file size
  1. Select At least or At most from the Size is drop-down list. This allows you to specify the minimum (At least) or maximum (At most) size for the file.
  2. Enter the amount of KB for the file size. For example, to search for files that are more than 1 MB, select At least in the Size is drop-down list and enter 1024 in the KB field.
