Asset Management › Software › File Explorer › Search for a File in the File Explorer › Search Files Based on the File Name and Location (BAR)
If you want to search for a file or a file pattern by using the name or location of the file, you can specify your search criteria accordingly in the Name & Location tab in the File Search dialog.
To search files based on the file name and location
- Enter the file name you want to search for in the Named field. Wildcards are also supported for the search function, such as *.txt for a search of all .txt files.
Note: You can search only for the files and folders available in the DSM file explorer.
- Enter the location for the folders (on a local drive or a mapped network drive) you want to search for in the Location field. Or, click Browse to locate the appropriate folders.
- (Optional) Select Include subfolders to include subfolders in the search.
Note: The file search option is not available in the Enterprise DSM Explorer.
More information:
Search Files Based on the Modified Date
