Use the UNIX Settings tab to configure the file scan collect task for agent computers running on UNIX environment.
To configure file scan collect task for UNIX environment
Note: File scan cannot retrieve files from directories for which the user is denied access to.
The Source list displays the sources that the file scan should include or exclude while scanning.
Removes the selected item from the Source list and does not scan it any longer.
Includes the selected item for scanning. Selecting an item that is set to exclude, includes it in scanning.
Excludes the selected item from scanning. Selecting an item that is set to include, excludes it from scanning.
Ignores empty directories while scanning.
Ignores non-executable files such as *.txt, *.doc while scanning.
Ignores the network directories on the agent computer while scanning.
Ignores the user login directories while scanning, such as /usr/bin.
