Use the Windows Settings tab to configure the file scan collect task for Windows agents.
To configure file scan collect task for Windows agent
Note: File scan cannot retrieve files from directories for which the user is denied access to. If the asset management agent is configured to file scan a network drive, the agent must be installed to run under the same user account that maps the network drive.
The Source list displays the sources that the file scan should include or exclude while scanning.
Removes the selected item from the Source list and does not scan it any longer.
Includes the selected item for scanning. Selecting an item that is set to exclude, includes it in scanning.
Excludes the selected item from scanning. Selecting an item that is set to include, excludes it from scanning.
Select Ignore non executable files to ignore non-executable files such as *.txt, *.doc when performing the scan. Click OK.
