The DSM Explorer › Control Panel › Configuration Folder › Configuration Policy › Configuration Policy Node (Control Panel) › Delete a Policy
Delete a Policy
If you do not need a policy any longer, you can delete it.
To delete a policy
- Right-click the policy in the tree view or in the Configuration Policy pane.
The context menu opens.
- Select Delete from the context menu, or click Delete Policy in the Tasks portlet of the Configuration Policy pane.
A standard Confirm Deletion dialog appears.
- Click OK.
The policy is removed from the policy list and deleted permanently.
Note: Deleting a policy automatically removes it from the assets to which it is assigned.
