The Query tab in the New Group dialog lets you select the query to be associated with the dynamic group so that, whenever there is a change in the query result, the group's membership can also change dynamically.
The tab contains the following fields:
Displays the date and time when the group was last evaluated with the query results. When you create a new group, this field shows Never.
Specifies the query you want to associate with the group. By default, this is set as None. When the default is None, a static group is created; but if you select a query from the drop-down list, a dynamic group is created.
Default: None
Specifies the engine that must evaluate the dynamic group.
Defines the frequency (in minutes) for evaluating the dynamic group with the query results.
