The DSM Explorer › Computers and Users Folder › Groups › View or Modify an Existing Group
Use the Group Properties dialog to view or modify the properties of an existing group.
To view or modify the properties of an existing group
- Click the group node you want to view or modify and then click the Properties icon on the standard toolbar.
The Group Properties dialog for the selected group appears.
- View or modify the properties and click OK.
The group is modified.
