The Group tab in the New Group dialog is used to create a new group of assets.
This dialog contains the following fields:
Defines a name that describes the members that this group is likely to contain.
Identifies the date and time when the group was created.
Identifies the name of the user who is creating the new group.
Identifies the date and time when the group was changed. At the time of group creation, this value is set to the creation date.
Identifies the name of the user who has modified the group.
Identifies the group type.
Defines the new group.
Specifies that the members of the selected group inherit the group permissions.
Note: At the time of creation, the Created by and Changed by fields display the name of the currently logged-in user. Also, the Members inherit permissions field may not be available in all Group tabs.
