The Status/Output Files contains the following information about the output files that the scanner produces:
Note: This table does not include the inventory file.
Attribute |
Type |
Description |
Name |
string |
Specifies the output file name |
Type |
string |
Specifies if the output file is an XCCDF or OVAL file |
Location |
string |
Specifies the location of the output file |
Timestamp |
string |
Specifies the date and time when the output file was created |
Size |
int64 |
Specifies the size of the output file in bytes |
